주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
MacBook stuck on grey screen with apple logo and spinning wheel
Macbook pro retina display stuck on grey screen with apple logo and spinning wheel i tried everything that i could find on the web even replaced my hard drive cable with new one my friend told me that he thinks it might be the hard drive but i also have windows 8 installed on my macbook and windows 8 is working fine but macintosh is not hopefully someone could tell me what could be wrong
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Help us help you. The more complete the description of your problem is (what Mac OS you're using, did you use bootcamp or some other emulator? Some history - when & why the behavior started) the more assistance we can provide, and, the sooner we can provide it.
When you say "tried everything" that means nothing to us. List the steps you have attempted, and their result.
Have you seen this article from Apple? If you are using Lion or later (OS ≥10.7 ) instead of a separate utitiles disk you would use Command-R. to access disk utilities.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
the mac os that im using os x maverick and i tried the disk utility i tried reparing it but it said everything is okay i also tried restarting the ram and also changed my ssd cable but nothing helped
also performed a safe boot and Reseted the NVRAM / PRAM and nothing happened
So how long have you left it spin? Sometimes it can take 10 minutes or more for a boot. The OS may be doing things in the background - especially if this was right after an upgrade to Mavericks. To reiterative: you are certian you have 1GB RAM, 9+GB HD space, and it's not an EFI update (dark bar) issue
댓글 달기
귀하의 답변을 추가하세요
junior 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 555
