주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Help with identifying components on logic board
Recently I connected my audioOut to a doggy Amplifier. A high voltage coming from the Amp destroyed my audio output, so that only one of the two channels is still working.
When I opened my computer today I found one component melted and signs of heat very close to the output.
Is anyone able to identify it and its function?
Is it possible to get replacement parts and solder it?
Thanks
Martin
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
thank you guys a lot. I'm gonna try the fix a.s.a. I get some spare time the next couple of weeks. I guess the iron shouldn't be to long on the board.
What temperature do you recommend for soldering?
댓글 달기
답변 2개
선택된 답변
oldturkey will surely tells you what exactly you need to order.
해당 답변은 도움이 되었습니까?
점수 3
댓글 10개:
my bad, faulty part is the DZ6706 but the pins out is the same than the DZ6704.
Lemerise is absolutely correct. The burned component is DZ6706. That is a 6.8V 100PF Zener Diode in a 0402 package. Mouser has them as part number750-CZRFR52C6V8
easy repair if nothing else is damaged.
yup, looks straight forward. How is Quebec this time of year? Tons of snow and frost:-)?
not much snow but it's cold. Keep warming by the hot air station hi hi hi...
댓글 5개 더보기
댓글 달기
Do you know about DZ18 on Iphone 5 (6.8V - 100pF 01005)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hector check your question on here find the part number DZ 18
댓글 달기
귀하의 답변을 추가하세요
Martin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 488
