How do I prevent my guitar's input jack from loosening?
The input jack on my Epiphone SG electric guitar keeps loosening after several hours of (nonconsecutive) play. I don't want to strip the backing plate screws by removing the plate to tighten the jack once a week! The jack on this model is on the front face of the guitar.
Other than looping the cable through the guitar's strap to prevent excess pressure on the jack, what's a good solution to this problem?
Possible ideas I've thought of include loc-tite (which I'd rather avoid) and replacing the jack's washers with larger diameter ones to prevent the tension from compressing the wood.
좋은 질문입니까?
댓글 6개
I added a toothed lock washer and cemented the outer and inner nuts together with liquid super glue (that's the variety to use for bonding metals).
Dale Alan Bryant 의
*output jack
Nick Williamson 의
Had the same problem with mine,i replaced it with a new jack. No problems since.
Austin 의
try installing a lockwasher between the nut & flat washer. They are fairly flat (not like the split type used on mechanical machines etc) and are radially serrated either along the outside or inside.
Henry 의
http://www.ehow.com/how_6743575_repair-j...
George Tirebiter 의
댓글 1개 더보기
