주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
Broken home button prong, can I make an alternate?
Ok, so I did a screen replacement on an iphone 5c. This was the second screen replacement on the same phone with in a 2 week time period. Both times phone was dropped. I replaced the screen and tested as much as I could without the pass code. When they got it home and had the pass code available they found everything functional but, the home button. I pulled it back apart and looked over everything and to my horror found one of the metal contact prongs for the home button had broken off. Is there anyway to fix this? Solder on a piece?
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Ok, I got it I replaced the whole charge port assemble which it was attached to!
Boy do I feel like a noob! I didn't properly understand your question (my fault, reading and repairing at same time is difficult!). I don't know why I suggested a home button flex when the prongs you were talking about were a part of the dock connector. Sorry!
댓글 달기
답변 2개
가장 유용한 답변
The home button flex for the 5c is very cheap and you don't have to worry about the touch ID sensor either, so go ahead and swap out the flex!
Trying to solder on the piece would not be effective, based upon time and cost expenditure compared to a new flex. You could cause more damage, you could possibly spend hours trying to solder it back on properly only to have it fail a week later, or you could just purchase a new flex for under $5 and install it in under 20 minutes.
I do not want to tell you how to proceed but if I were in your position, I would just replace the flex.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
You don't even have to hunt around online for the best deal! You can find it all here on ifixit.
iPhone 5c Home Button Ribbon Cable
Hi Eric, I clicked your profile to try and send you a message today--no email listed. I sent you a note through your Device Savers page. Let me know if you got it. (I will delete this comment later).
I don't see any messages but I added my email to my about me section.
댓글 달기
Looks like you got a solution, awesome!
I do a lot of iPhone 5 no home, no power pry damage repair and we have to test the home button function on passcode locked devices, and devices that are not activated. Here are some tricks we've learned:
If you have the device locked, aka sleeping, via the lock/unlock button---then pushing the home button should wake up the phone.
If the device is on iOS 8, and post battery disconnect, so that it is really grumpy for that passcode, you can confirm home button function by doing a hard reset---the power and home button will force the phone to restart when held together for 10 seconds. Both buttons must work for this to happen.
If it is just passcode locked, then flipping up to the camera and then hitting the home button will bring you back to the lock screen.
If it is on the activation wizard after a restore, then click through a few pages. Pushing the home button will bring up a 'cancel/start over/emergency call' dialog.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kerri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,879
