주요 콘텐츠로 건너뛰기
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 질문 전체 보기
질문 마감됨
Digitizer and LCD touching
Had to replacement both glass and LCD.
After installing both parts, with enough pressure, the digitizer will touch the LCD.
Should I add another layer of adhesive tape around the edge for more clearance?
Thanks,
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi Steve,
I would take the iPad back apart and inspect. It doesn't sound like your LCD is seated properly in the housing. I would remove the glass and LCD and make sure nothing like adhesive or glass is down there and is causing your LCD to not seat properly
If you are sure that the LCD is seated properly, I would check the iPads frame for bending. If the frame of the iPad is bent its possible its causing the issue, It will need to be replaced.
The frames can bend if it sustained a hard enough drop.
Also ensure the battery is completely seated. If the battery is not seated 100% it can push the LCD out and cause it to touch the glass.
Hope some of this helps!
V/R
Josh.O
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Nope. Take it apart, find the shard of glass that is lifting your LCD, remove and seal.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 339
