주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf Maverick는 이 회사 제품군 중 가장 인기 있는 총기 중 하나로, 단순함과 사용 편의성 덕분에 많은 사랑을 받고 있습니다.
Why won't my gun fire?
The gun seems to be cocking correctly, but when I pull the trigger nothing happens.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 2개
선택된 해법
Plunger Misalignment
The plunger propels the bullets by air pressure. Often times after disassembly, the plunger can become misaligned with the holes in the barrel. Simply re-positioning the plunger so that its air flows directly into the barrel will solve the problem.
Bad Seal in Plunger
The plunger is made up of two tubes, one inside of the other. The outer tube is pulled back when the gun is cocked and forces air out the inner tube when the trigger is pulled. There is an rubber o-ring seal between the two tubes which forces the air to flow in the correct direction. If this seal fails, the air will not reach the bullet with enough pressure to fire. If this happens, the o-ring must be replaced. Home centers should have the appropriate size in the plumbing section, or a rubber band may be used as a substitute.
See the O-Ring Replacement Guide for more details.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My nerf Infinus’s trigger is jammed and it won’t shoot how do I fix it
댓글 달기
It is difficult to give a correct answer without diagnostics, there can be many different reasons, but most likely it is a matter in the starter unit. I'll leave it here https://blasterhero.com/nerf-gun/how-to-... hope it helps you.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
piece of garbage fired 1 time
댓글 달기
답변을 추가하세요
Michael Walker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 25
전체 시간: 13,863
