주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
What is the GPU? Is it SGX535 or rumored SGX545?
I'm very curious as to why the GPU wasn't mentioned. What is the GPU in the iPhone 4? Is it the same SGX535 in iPad and 3GS or did Apple go with the SGX545, which has been a rumor for sometime?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
Monteiro2008
Iphone4 use SGX545, and this GPU graphics boost over the current SGX535 in the iPhone 3GS: up from 28 million polygons per second to 40 million in SGX545.
This Gpu run:
DirectX10.1 API support
Enhanced support for DirectX10 Geometry Shaders
DirectX10 Data assembler support (Vertex, primitive and instance ID generation)
Render target resource array support
Full arbitrary non power of two texture support
Full filtering support for F16 texture types
Support for all DirectX10 mandated texture formats
Sampling from unresolved MSAA surfaces
Support for Gamma on output pixels
Order dependent coverage based AA (anti-aliased lines)
Enhanced line rasterisation
SGX545 was also designed to deliver full profile OpenCL 1.0 capabilities, with advanced features including:
Support of round-to-nearest for floating-point math
Full 32-bit integer support (includes add, multiply and divide)
64-bit integer emulation
3D texture support
Support for the maximum 2D and 3D image sizes specified in the full profile.
Inside POWERVR SGX545
USSE (Universal Scalable Shader Engine), the main programmable processing unit within each POWERVR SGX545 pipeline, is a scalable multi-threaded GPU shader processing engine that efficiently processes graphics as well as many other mathematically-intensive tasks. USSE can be programmed using the GLSL language that forms part of the OpenGL ES 2.0 specification, or in the C-based parallel processing language used in the OpenCL specification – both APIs from the Khronos Group.
POWERVR SGX545 delivers the broadest range of graphics API feature sets in the industry, while also enabling developers to gain greater access to the full capabilities of the USSE-powered GP-GPU in a broad range of applications including digital imaging, video processing, game physics, cryptography, and other general computing tasks that can benefit from parallel processing.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Click here
You might want to look at the webpage above. It contains everything you want to know about the iPhone, iPad, and iPod Touch. It is updated often, so check back for the most current secrets.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I fixed up the links for you and + for the site, nice info there.
댓글 달기
aarrrghh - SGX535 (also in the intel gma500)
i don't know it for sure - but it worked in the past and i think it will work in the future
take the iPhone 4, wait a few days until a good jailbreak is out (it's already done) and use a tool like ifunbox to simply compare the used gpu kext of the devices.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Wes McDermott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 7,849
