주요 콘텐츠로 건너뛰기
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
26 질문 전체 보기
How to fix audio jack at the end of the cord?
The small mm jack at the end of my headset has come undone from the plastic seal around the wiring. So the green jack kind of just flops around. Now there is no sound coming to the headphones whenever it is plugged into an audio source. Is there any way to fix this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Matt Thomas, yes there is . The green 3.5mm jack is your audio, so you obviously have some broken connection. Replace the jack the same way you would on a regular headset. Take a look at this guide to see how to replace an audio jack. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Matt Thomas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 20,265
