주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s not coming on
Iphone 5s, after i lent my charger to my aunt my phone refused to charge...it would charge to 3% / 4% would not charge any further . then when i try to use it the screen flickered on and off then died. thinking that it was a battery failure i replaced the battery and i have not gotten it to turn on since. im a cellular tech and tried everything in my power now im asking for advise.
The only thing i haven't tried is ordering a brand new batter/charging port or a new charger.
can anyone advise me on whats going on or what caused this i would appreciate it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
For a no power problem you're right to think battery, and then new dock connector.
A new battery should turn the phone on. If not, then you may have a different problem.
First rule out bad (new) battery, then dock connector. After that we will start thinking about the board. Make sure to test if the phone is on by connecting it to iTunes---that way a no display issue won't get in the way of your troubleshooting
jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
im going to buy a oem charger and connect it with out a battery if the phone does not go into a boot lop then im looking at a board issue. if so i would like to figure out why
the phone probably will boot loop with no battery installed. stick a new battery in there. it should boot from a new battery, they come with residual charge
댓글 달기
You did say the screen flickered and wouldn't turn on it could be the display but thats a long shot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
matthewlevy300 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 298
