주요 콘텐츠로 건너뛰기
모델 A1106 / 1280x854 스크린 해상도
90 질문 전체 보기
No chime at startup, powers down spontaneously
I just replaced the PRAM battery and it doesn't seem to have helped. The computer charges its own battery, which is in good shape. Here's the dominant symptom: I press the power button and it boots up, occasionally remaining on all the way through to the usual desktop. I get a plackard asking me to reset the date, which I do - and then at some random point shortly after that the machine powers down (quickly). Most of the time the machine doesn't even make it past the Apple logo - just a quick power down. I have reset the PMU many times, and the PRAM - if it even lets me. The key, it appears, to having the most time before the machine shuts off again is to wait longer between boot attempts. If I go overnight it will stay on maybe three - four minutes. After that shutoff, though, it will only remain on for ten, maybe fifteen seconds. Any ideas are appreciated. I'm thinking it might be the DC board, but since it powers on and charges the battery I'm not so sure.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
well stated question +
댓글 달기
답변 2개
선택된 답변
sound like a narcoleptic PowerBook
this problem were pretty common on those aluminum g4 PowerBooks.
it's a defective temperature sensor right under the trackpad.
the best way to solve this, is to remove the sensor completely
you can read more about it here (click me)
the sensor is shown here (click me) - right between the two white connectors
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
댓글 달기
Spectacular. I only wish that 'narcolepsy' was part of my original keywording. I had the thing open when I got this suggestion. 1 close-magnification loupe, 1 x-acto blade to saw the posts, and it's worked for the last two hours (beyond the three minutes or so it'd work before shutting down).
Thank you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
matthewgilson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 9
전체 시간: 1,588
