주요 콘텐츠로 건너뛰기
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
798 질문 전체 보기
Why is my kindle fire hd having sound but no picture?
My kindle fire HD has sound and I can hear noises coming out of my kindle. However my screen is showing no picture comeing through? How can I fix this as restarting is doing nothing to help my kindle fire?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 12
댓글 6개
i have same problem. did you find a solution?
i also have the same problem...did u find a solution yet
aaron81182 I was wondering if you got your issue fixed? Please see my reply about how I fixed it.
Mine just started doing this like 3 days ago and I CANNOT figure it out!
I did the 40 second hold on the power button and it worked
댓글 1개 더보기
댓글 달기
답변 7개
가장 유용한 답변
I watched the you tube video. Held the power button for at least 40 seconds and screen came back!
해당 답변은 도움이 되었습니까?
점수 5
댓글 5개:
Wow...I was very skeptical but this worked!
Genius! Thankyou.
Unbelievable.....IT WORKED......THANK YOU
It worked, thanks so much for posting!
I was a little leary to but it worked
댓글 달기
katie, since you have nothing showing on your screen regardless of what you do, I would suggest that you use this guide. Check to make sure that your LCD is properly connected and that you do not see any obvious damage to the cable and any of the components on the board. It is possible that you have a bad LCD (or bad backlight), replace it and let us know what you find.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I had the same issue and Amazon was no help. I had to take the back cover off and unhook the battery. Next you re-hook the battery and the kindle started working. I had to re-set everything-clock, wifi, etc... but at least it's working.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
This is what helped with the issue mine had.
댓글 달기
Tried all the above, unconnecting and reconnecting the battery, holding down the power button, nothing works, the light is coming on the screen but there are no images, my son put it to charge and that happened.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Me too Pamela. Nothing has resolved it. Any updates?
댓글 달기
My kindle fire has sound the screen is black. I’ve also un-hooked the battery several times. Thought I had it on the first try, nope. I have a full charge on it cause the screen comes on for a spilt second then goes back to black. Tired holding the power button for 20, 30, 40,50 seconds still doesn’t give me a functioning screen. About ready to call it quits. This happen about 4yrs ago and thought just maybe nope still doesn’t work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
my amazon tablet is not working but it just making sound but no pictures can you help me fix it
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Mind is the relevant get my back of
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
katie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 55
전체 시간: 22,589
