Only the left side of the headphones is working
When I tried to use the headphones only the left side was working, I checked to see if it was broken in any way but it wasn't.
좋은 질문 입니까?
좋은 질문 입니까?
Godsmack,you want to start with a check of the wiring itself. Use an ohm meter and check for continuity between the jack and the control box (bass boost) and from the control box to the left driver (speaker). If you find that the error is with the jack, here is the guide for replacing the jack.
해당 답변은 도움이 되었습니까?
Should be a loss of contact inside the audio jack. If you can try to replace the jack with another one or you can pull or move around the cable to see if audio restores itself from that side (experienced the same thing different times with different headphones after some use).
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 1,737
