주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
Fingerprint sensor not working
I tore the home button flex cable just a bit and now the Touch ID doesn't work. It's still the original home button and assembly. If I replace just that home button cable that is taped to the screen shield will that solve the problem allowing the Touch ID to work again?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 22
댓글 5개
Can a replacement cable fix this problem? I've seen them for sale online and wonder if removing the torn one from the original Home button and attaching a replacement will fix this?
If you do replace with a knock off home button meaning not original. You cannot restore it it will throw in iTunes error code. Also there is a chance that the microphone for Siri and dictation will not work. Also when your phone sleeps when you press the home button sometimes it will do nothing. Will not wake the screen up
Why is it that when I don't have the original home button, it doesn't work and even when I buy new original home button onto my iPhone it still doesn't work?
Because there is only one original home button to your phone on this planet, you can’t buy another home button and call it original. If you lose it you lose Touch ID forever.
Do a DFU restore and your touch ID will work again. Re
installs firmware on device as factory and will start reading again. Works for screen problems and touch id sensor. Does not have to be original.
댓글 달기
답변 20개
선택된 해법
If you replace the cable it should work. It only doesn't work if you don't have the original home button. more info
이 답변이 도움이 되었나요?
점수 8
댓글 2개:
Try replacing the cable.
Get the super cheap phone repair kit @65% off, hurry now
Would you mind looking at my question about this, I think you answered my question but I would like to be certain or get more info. Thank you
댓글 달기
Try to disguise the damage and send it back to Apple. Only Apple can repair the Touch ID button on this planet.
Do not replace the button, for iPhone 6, mismatched home button will cause the phone to be entirely inoperable.
If you are sure that just the extension cable is broken, replace it and it will work again.
이 답변이 도움이 되었나요?
점수 7
댓글 8개:
I know it's the cable for sure I saw it tear where it is taped to the LCD shield. I just ordered some new cables and will install and update then.
Albert did it work?
You can use a mismatched fingerprint reader just fine. They're cheap off of ebay.
But the finger print function will never work again.
They're serial number locked to your IMEI..
However if your jailbroken you can access the P list setting for the fingerprint scanner and edit it. Then you have a full functioning working scanner I know because I've done this I change my silver iPhone 6 Plus to a black all black screen with replacement fingerprint scanner. After modifying P list it's a simple respring
Does anyone have the exact process for editing the files?
댓글 3개 더보기
댓글 달기
I tried replacing the ribbon to cure a faulty home button but it didn't work for me, don't know if it was a faulty replacement cable or not.
I'll be watching with interest.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You can only replace the fingerprint scanner if your jailbroken and have iFile. Must have access to the whole entire root filesystem. From there you can access the Plist file you need to modify. It is link with the serial number but a simple and it can fix this. I know because I've done this on my iPhone 6 Plus. I change the color of my screen and home button to black. Was originally white. Once you modify the file simple respring and you're good to go
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
After doing this can i unjailbrake my phone and have the home button work with the fingerprint?
What .plist file is the one to be modified and what do you change the data to in order for the scanner to work?
Which .plist file did you edit?
Can i use ibackupbot software instead of jailbreak?. can someone try it? i mean use itunes backup and open backup file with ibackupbot.exe software and find the Plist file. after you edit the Plist file save backup. and then go back to itunes to restore it. i just saw on google someone change restriction password with this kind of method. so i wanna ask if this possible to change the Plist without jailbreak?
댓글 달기
No you cannot it will throw in AirTunes code 55 or 35 I believe because you need the original home button to restore
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
댓글 달기
When i go to my touch id & passcode and when i go to add fingerprint it says unable to complete touch id setup.go back and try again
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I have Same Problem I Replace New LCD & Digitizer Everything Working Fine Just Touch ID Not Working If Any one Have Problem Solution please Let me Know Thanks
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Buy the plate that goes on the back of the lcd (can't remember what it;s called) if that's even what you're talking about.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
EFI Shield is the name of the backing plate
댓글 달기
nice orginal home button is broken and error 53 and iphone is trash stuff now byebye 900 euros phone and never again apple products (i swap lcd and broke the home button) so far there is now fix for this ? ::DD this is not good joke
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
It's not a joke. But it's not a permanent fix either. It's a temporary fix for someone who is jailbroken ill upload the plist settings on I file later on tonight
Alex you got the Touch ID plist to fix sensor?
I have access to root but need the steps and file to get Touch ID working again. Thanks
댓글 달기
Anyone got those plist settings yet?
Also, I take it that if you have tried to restore and got error 53 already, there is no way to get out of recovery and go on to jailbreak?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yeah i dont thinks so that is possible anyways byebye apple i go to grab huawei p8 today
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You should be good to go now. Apple patch the problem with the finger print scanners I just ran into one today and restored it no problem
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
how to modify plist file?
do you have a link Alex?
댓글 달기
so its confirmed if you just broke the long flex cable, replacing that, but using the original home button, you are fine for touchid functionality?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yes, as long as you use the original home button you can replace the long flex or extension flex cable if it is damage and your finger print sensor will keep working.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you replace the Metal Backplate, it will fix the issue you are having as long as you are using the same home button. The cable that runs through the plate and connects to your home botton should be included with the assembly. The metal backplate assembly only cost me $8.95. I had made the mistake of cutting that cable as well getting it off the bottom part of the phone so I understand your frustration of a perfect screen replacement. Home button and Touch ID still work on my phone.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
So you have to use the same original home button?
That is correct if you still would like to use the finger recognition. If you use a replacement home button, the button will only be able to take you back to the home screen, Touch ID will Not work.
I have the same problem. Where can I get the metal backplate and home button together ?
댓글 달기
my touch id is broken, i tried to update iOS and I got error 53. How may i work it around?? Please help me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I am from myanmar.Now, I'm in the trouble of touch ID after the replacement of home bottom from the service shop.Plz reply to -tootp.htetnaing@gmail.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Do I have to download an app to start the finger scan for the iphone6?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Fingerprint is all an hardware issue... No software can fix...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Fingerprints not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Albert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 38
전체 시간: 102,557
