주요 콘텐츠로 건너뛰기
The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
Why do the speakers of my device sound distorted?
My Air Raid sounds choppy, the music cutting in and out every few seconds. How can I fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Make sure that only one device is connected via Bluetooth to your Air Raid. When one audio device is connected to the Air Raid, and another attempts to pair with the Air Raid, it may result in choppy audio. Normally this should only last for less than 30 seconds. You can also reset the paired device list by holding Volume + button and the center button for 5 seconds. To completely “forget” audio devices and start fresh simply go into the pairing settings on your streaming audio device and remove the Air Raid, then pair again. If your speakers continue to sound distorted, they may have permanent damage. A replacement guide is available for you to fix your Air Raid.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
you can go to Skullcandy Air Raid Troubleshooting for more help troubleshooting
Perfect, my Soundmine was being a dink but it was because my phone was competing with my laptop for Bluetoothiness!
댓글 달기
You may need to clean it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sasha Nevin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 1,797
