주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Dropped iPhone - No image, no vibrate
Hi.
So I dropped my iPhone and when I picked it up the screen was black (though the backlight was on). The vibration button was not working, but the phone was definitely on. I tried all types of resets. Nothing worked.
When I plug in iPhone to my Mac, iTunes sees it. I tried to restore iPhone, that's when vibration once worked. But still the screen is not working.
I disassembled the screen and put it back together - still only backlight sometimes.
What do I do next? What can be wrong?
Thanx in advance, I'm both scared and fascinated :D
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개:
Hello i'm having the same issue, the phone fell to the ground and won't turn on anymore.
iTunes recognizes the device, but black screen won't let me unlock it.
Furthermore, when i plug it to the wall charger(with phone turned off), vibration seems to be struck on loop. It pulses with same timing, same distance between vibrations, till is plugged in. When disconnected it stops.
I'm afraid it a logic board problem, but before investing 160$+ in a brand new one, i would like to be sure of that. Many thanks in advance, and good fixes :P
EDIT: im using this discussion as reference: Black screen, keeps vibrating w/ power cable
i will try it!
댓글 달기
답변 1개
Try a new screen to rule out a defective one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dan Fire 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 245
