주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Missing what I think is a Resistor but not sure exactly.
Ok so I have a water damaged IPhone 5c . I disassembled and cleaned with 99% alcohol but still nothing so i proceeded to remove the Metal shields where i found more corrosion which i cleaned with a brush and alcohol .
After cleaning i reassembled with a new battery . The phone shows no signs of life other than the board gets hot enough to burn in this area SHOWN IN BLACK .
Now i noticed that what looks like a resistor but is probably not was covered in corrosion and looked damaged and seemed to be the source of the heat. would burn finger when touched. So i successfully desoldered it and no more heat but still no life in the phone. I'm looking to find out what this part is called so i can get a replacement to see if it solves the issue.
Part shown in black
These images were taken from ifixit i just highlighted the part i am referring to.
Thank you in advanced.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
st3v3w, that is reference designator L11 which is a 2.2UH-20%-1.7A-200MOHM inductor (coil). It is listed as a TFA201610G which is manufactured by TDK
해당 답변은 도움이 되었습니까?
점수 1
댓글 9개:
Thank you oldturkey03 your knowledge is greatly appreciated.
Sorry to bother you again but i have been looking for this part but seem to be having trouble find it . do you have any recommendations as to where i could find it?
Where in the world are you located?
Canada , New Brunswick .
Lets see if we can find the right component. If you can, measure the components physical size. That way we could find an equivalent package size. I'd try to check Murata's LQM2HPN2R2MGH and see if the dimensions would be workable. You doing okay with all the snow and bad weather?
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
st3v3w 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 158
