주요 콘텐츠로 건너뛰기
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Where does the rubber plug inside of filler door drain to?
1978 mercedes w123 diesel. Inside of fuel door is a rubber plug conical in shape.
does it drain rain water to the outside or does it have another function? threaded plastic weed wacker line to see if i could find the exit area and I did not see it.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
It also covers over filling or expansion of gasoline.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Drains to outside below rr fender. If you cannot see your wacker line, the rubber tube may be separated or torn. Push your line as far as you can then reach up inside the fender and feel for it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mike anthony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 477
