My battery drains quickly Even After replacement?
Hi
My iPhone 5 is draining battery Power rapidly, i have changed the battery for a New one, however this as not resolved the Problem.
Googled the issue, but not Fond a article/ Blog that resolves the issue
The phone does Not get warm
The phone is not jailbreaked
Background Apps / not often used Apps are disabled,
Photos reduced (saved to PC)
Videos reduced ( saved to PC)
Can there be some other Part that using soo much power?
Can it lie purely on a software Problem or can it be a Hardware problem ?
좋은 질문 입니까?
댓글 4개
How update to date is your phone? Also have you tried letting the phone drain completely dead and then charge completely full without unplugging. Usually doing this drains the phone to adjust to the new battery. If that doesnt work you could just make sure your software is up to date or do a reset.
Brandon Bauer 의
Hi Brandon, the phone is at the newest stand regarding updates, also tried all that what you have suggested, to no avail of it resolving the issue. thank you all the same
Haydn 의
I use to have this problem as well and I realized that applications on phone can drain your battery. I use the battery usage feature to see which app is draining my battery and then update the apps. It worked for me. If you need more information please visit: http://www.technobezz.com/iphone-battery...
carolinemyers13 의
Recently I have replaced my iPhone 6s battery due to battery drainage. But after replacement also I am getting same battery drainage problem. My biggest concern is , in stand by mode , battery drained like anything.
manas sahoo 의
