주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
programming new optical drive for replacement
hi im just wondering if you have to program THE NEW optical drive IN XBOX ONE LIKE THE OLD 360S
THE TUTORIAL SHOWS THAT WE JUST SWAP THEM OUT BUT WILL GAMES WORK ON THE NEW DRIVE ?? i read that the drives are motherboard locked so how does this tutorial work ?? I also read that you have to swap out the board on the original drive to the new one in order for it to work but the tutorial does no such thing can someone shed some light on this thanks !!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
My Xbox one S has no optical drive at all.. How do I install a new one if I don't have a daughter board??
@rottenova Simple, it's just not possible.
댓글 달기
답변 2개
선택된 답변
You have to swap the daughterboard from the origianal optical drive that came with the console from the factory with the daugtherboard with the new drive you are going to install. Each optical drive daughterboard is married to the motherboard so it must stay with that motherboard even if the drive is swapped out.
You will need to desolder the wires for the motor and solder them back on the replacement board.
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
I’ve done that, but my drive still won’t read games or DVDS what do I do in this case?
@Nate Khan Replace the laser
Is there anyway to know what daughterboard is attached to what motherboard? I have a bunch of systems that have been mixed up due to a big move. I can't find this answer anywhere. Specifically the Xbox One S.
Same here^^^ is there away to swap out the motherboard chip that links the disc drive to one from another Xbox
댓글 달기
I replaced my Disk drive on my original xbox one Halo version. With a Disk drive Order from Amazon. Unsoldered and re soldered daughter board to new Disk drive. It will take the disk in try to read it then I get a black-and-white Square message DVD Blu-Ray disk or game does not recognized please insert and DVD blu Ray disk or game. How do I get my xbox to start to read disks again
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sahilvinay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 82
전체 시간: 9,245
