주요 콘텐츠로 건너뛰기
Model A1288 / 8, 16, or 32 GB capacity
451 질문 전체 보기
How to Solder replacement headphone jack?
Hi I have an iPod touch 2nd gen in which the audio is coming out of one side only. I found an oem replacement part on ebay for only $4 but replacing this would require soldering. So anyone know how to do this. I looked at the part and there is a ribbon cable on top of the five or so contacts that need to be soldered making it hard to approach.
Update
so can anyone post a guide on how to do it Ive soldered on the spring that is attached to the logic board for the home button so soldering itself is not a problem. Just not sure what exactly to solder for the audio jack.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
since the headphone jack is a mechanical part - ic could normally be fixed without replacing - but if you don't have any clue of those things - let it be!
i don't know what nick is trying to say with his answer - surely it't no real "component level repair" - the part is way to large for that category. but if you don't know how to use a soldering iron - find someone who is able to do that.
i think the mentioned microsolder is a "special product" - there are many smd soldering tip's - but changing the headphone jack doesn't require those tiny "needle" tip's - a regular small soldering tip is good enough.
but i would first check the headphone jack for dirt or something like that - it's not normal that those parts are getting mechanically damaged (mostly they die when you try to remove the logicboard - but with normal usage - you can't tear it of the logic board)
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
+ Ralph
댓글 달기
Hi All,
If the plug is broken that is tough to replace. The circuit boards are sensitive to heat from most soldering irons.
One trick I can recommend to make it less prone to damage in the first place is adding a right angle jack and then plugging your headphones or other device jack into the right angle connector (Radio Shack/The Source P/N: 274-372).
Good luck... RM
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I hope that you have checked your headphones as well - the mating connector on your headphones could be damaged. If you have to replace the jack on your ipod, there is a useful guide about how to solder with a soldering iron at:
http://soldering-irons.com/how-to-solder...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
siberok92 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 8,832
