주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Modify li-ion charger to charge iPhone battery?
Disclaimer: this question might show a complete lack of understanding of the finesse of electronics.
My iPhone 4S' charging circuit is not working properly, so I am looking at convenient ways of charging the battery outside of the phone.
I've found a circuit diagram posted here by oldturkey03, and I will give that a shot.
Then I had another thought; I do have old li-ion chargers, for digital cameras and such. If one of these has the correct voltage (3.7V) and the correct current rating (<=1000mA), would it be up for the task, or could this still break my battery?
Update
I've been using this setup many times now and it's working great:
I have very simply connected the + and - terminals of the charger to the corresponding pins of the battery. Most of the jumper cables are used to keep the battery in place.
By a strike of luck, the small jumper wires fit very well into the battery plug.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
cerapter, as long as it provides some kind of overcharge protection, it should be okay. Consider getting your iPhone repaired so you do not have to do this for very long. Could become a royal PITA to external charge it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you, that is what I was hoping to hear! It is a PITA, yes, but slightly less so if I don't have to mount the battery in another iPhone to charge. Another risky idea I am having is touching the charging wires to the battery port inside of the iPhone, without undoing any screws. I'm a little worried about frying nearby components, though.
This is now working very well. Since I have three batteries, I simply switch to a fully charged one when I run out of juice. I do have to undo the screws every time, but it's not such a PITA as I'd expected.
댓글 달기
귀하의 답변을 추가하세요
cerapter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 386
