주요 콘텐츠로 건너뛰기
Tasty fruit. Good source of potassium. Yellow.
2 질문 전체 보기
How can I tell?
I can't tell if I have a banana or avocado or maybe a dog? I might even have a mink pelt. I just wish there was a way to see if what I was holding and attempting to eat is actually a banana.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 달기
답변 5개
선택된 답변
In case you are blind, bring in a monkey, wait 5 minutes, feel for which item is missing.
해당 답변은 도움이 되었습니까?
점수 9
댓글 2개:
What if it were a plantain?
Then it wouldn't be a banana.
댓글 달기
Does the device emit a sound of any kind (while stationary)? Does it appear to have an on/off switch?
If it makes a sound, or has an on/off switch, it is NOT a banana.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
is there a way you can post a picture of the device? it could be any of those. What are the specifications? or is it a knock off?
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Bit in if it bits back it was the dog
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Just make sure that the device is yellow and crescent moon shaped. If it has legs, then it's probably not edible in that state. If it's green, it may be an avocado. Hope this helps...
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
if its green it also could be a cucumber, lime, or even a plantain. There are many options.
All of these green options are edible, however a lime is incredibly sour, and the anti-opening device in the lime will cause temporary blindness if the fluid is caught in the idea. A cucumber is extremely ovular. A plantain looks like a banana, but you may encounter bitterness. This is the anti-opening device.
the blindness will come from a lemon that has been died green.
That’s dyed green.
댓글 달기
귀하의 답변을 추가하세요
Yaxfer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 19
전체 시간: 534
