주요 콘텐츠로 건너뛰기
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 질문 전체 보기
질문 마감됨
Battery indicator is malfunctioning please help
actually i bought samsung galaxy tab 2 model GT p 3110 about a year ago. Since the last few months it has got some problem . Actually if the tab is not charging, the battery indicator shows tha the tab is charging and makes it upto 100% after that it suddenly comes to 1%. Please give a solution for it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
How long is it running at 1% & does it automatically shut down at that point ? The lithium batteries have a built in chip that communicates the estimated battery level to the device. Most often devices are charged before the battery is discharged, needing only a top off to 100%. The chip needs to be recalibrated occasionally. Usually letting it run down until the device automatically shuts off & then recharging the battery to 100% is sufficient, but that has to be a single session for the chip to recalibrate. See if that helps
Cheers
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 485
