주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
394 질문 전체 보기
Adhesive for the glass on the screen
Hi, I had to replace the glass cover as the old one had cracked.
The only problem is that the new perspex/glass cover had only double sided sticky tape on it to hold it onto the metal behind it and is coming off every time I open/close my mac even after removing the old glue from the metal section
I was wondering if there is any sort of adhesive strips I could get to attach it properly or even double sided sticky foam but what thickness would you recommend..
I've searched online and I can't find any strips to buy locally (I live in the UK) so I would be happy using the foam but I'm unsure as to the thickness.. :S
Many thanks!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Before buying another kind of tape try heating up the glass and with a cloth (so you don't burn your fingers) go around pushing it agains the frame. Don't heat it too much so you don't melt the rubber gasket
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I use Red tape for repairs like this. Found on eBay just search for "red repair tape" 8 or 10mm should work for you
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kcnbob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 936
