gateway power on but screen stay black
power light come on but the screen stay black
좋은 질문 입니까?
좋은 질문 입니까?
3 possiblities:
1-bad ram module
2-remove ALL power supply to unit. Battery, power cord. Push and hold power button for 60 seconds. Try it now.
3-bad inverter board or backlight bulb.
해당 답변은 도움이 되었습니까?
One way or t'other, it did work. Thanks.
try adding a new os it may just need a new os no garentees that it will work
해당 답변은 도움이 되었습니까?
I added the ibm t43 hdd to my gateway laptop and it worked like normal
I have turned on the computer but the screen is blue and I am traveling wanting to watch a movie
It comes on but screen is blue
해당 답변은 도움이 되었습니까?
My PC will turn on, but there is no beep when it starts (it used to beep when turned on and everything workeds fine) and there is no signal to the screen
해당 답변은 도움이 되었습니까?
NE56R41u power on then shuts off after 5 seconds. No beep. Black screen.
Did all the standard troubleshooting before disassembled it. Same behavior with naked mainboard.
Is this MB failure?
해당 답변은 도움이 되었습니까?
24 시간 전: 8
7일 전: 57
30일 전: 247
전체 시간: 26,110
Does the pc give a series of beeps when you turn it on? If so how many beeps?
Jeff DeVaun 의
no it does not beep
mrsizzy209 의
Yes 2 beep when powered up
terryconnock 의
