주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
How would I fix my flickering screen?
Hello
I've had my iPhone 4 for a while and not long ago I woke up and my screen starting flickering (mainly white). I can't see it acess my iPhone. I can hear it though, if I unlock it I hear the unlock sound so it's not totally broken. The screen is also pretty badly cracked. So what would be the problem? The LCD? The battery? How would I go about fixing it? What part(s) should I buy? Also I tried restoring so it's not software.
Other info:
- it could've gotten water damaged, I mean there's no way I could tell waters everywhere in life
-everything functions fine (touch abilities, sound, buttons, etc.)
-I have used a 3rd party iPhone repair shop to replace the screen but i don't think they did it, the problem occurred after more than 6 months of the repair
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It very well might not be fault of a non-authorised repair shop. They might have paid a high price to get a fine part, which turns out to be shoddy. You may have better luck with a second replacement.
댓글 달기
답변 1개
가장 유용한 답변
You might have a LCD Cable that was jarred loose. Or, the LCD could be faulty. You should open it and try reseating the cable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Raymond Villalobos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 158
