주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
다양한 소형 엔진 수리 안내서 및 지원.
How do I cure this?
My ride on mower starts fine and ticks over as it should but when I release the brake and try to move forward or reverse the engine stalls then dies completely, it will not move in any direction. Also if I try to engage the blades the divine then stalls and cuts out. Any ideas how to stop this ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
What make and model is your mower?
댓글 달기
답변 5개
가장 유용한 답변
Sounds like the seat safety switch is not depressed when you sit on the mower...assuming you have a rider mower or some other safety device like a blade break is stuck in on position
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Does the machine stall when you only release the brake or do you have to try to move in a direction before it will stall?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Does your stall just when you let off of the break? or do you have to try and move in a certain direction before it stalls?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
let start with a model number and a mfg. This sounds like a safety switch like an operator present switch under or near the seat. Depending on the model, it could be a pressure switch under the seat or near the frame/seat fold pivot that has a grounding tab contact there.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check and make sure you don't have some rope or wire or something around your lawn mower blades stopping the blades from turning built up grass possibly without more information it sounds like something is stopping your blades from turning
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Seths mam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 672
