주요 콘텐츠로 건너뛰기
24" 화면; 내장 iSight 카메라, 마이크 및 스피커; 1920x1200 해상도. 2008년 10월 출시, 모델 번호 A1267로 식별.
84 질문 전체 보기
Flickering band running down display
I have a band about 1 inch wide going down the right side of my Apple flat panel monitor. It looks like very thin white lines constantly flickering on the screen. Is this indicative of a bad DVI cable or a problem with the screen itself? Any information would be helpful.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
I Have seen this in my brother's laptop, some forums say it is a display panel issue, others say it is a video-ram issue, try hooking up annother display, if it does the same, your computers graphics card is bad, also, which apple display, is it a Studio Display (3 Legged Picture frame like thing with powermac G4's and early G5's) or is it a Cinima Display (Newer Aluminum Displays Matching The PowerMac G5 and Mac Pro) or is it a LED Cinima Display( newer LED Backlight with a Mini-Displayport connector for MacBooks and Mac Mini's)?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Oops, if it's external, than it won't be the video card causing the problem. I thought it was a MacBook display. Anyway, it seems like you have a bad panel.
댓글 달기
Try with a different DVI cable and different input computers to see if it is the screen. If it works with a different cable/computer then the display is fine. If the problem remains the display is broke and I think when that happens you need a new one.
Someone correct me if there is a way of repairing a LCD
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
the dvi cable is built into your monitor, so its hard to replace that... could be a bad pin on it or a bad inverter assembly inside. theres not much you can do to fix it without some specialized apple or lcd repair shop that deals in re cabling the screens
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Have you tried attaching your display to another computer to see if the trouble still occurs?
If it doesn't you have a display driver/hardware issue that you need to address.
If it does, you are in some trouble. With a built-in cable, all you might be able to do yourself is open the monitor up and see if the connection is good on the monitor side, and reattach as necessary.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
does anybody know the serial number ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dash 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 10
전체 시간: 6,895
