Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
좋은 질문 입니까?
좋은 질문 입니까?
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
해당 답변은 도움이 되었습니까?
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
해당 답변은 도움이 되었습니까?
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
해당 답변은 도움이 되었습니까?
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
해당 답변은 도움이 되었습니까?
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
24 시간 전: 3
7일 전: 9
30일 전: 17
전체 시간: 6,763
