주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Samsung printers.
Ink smudges from Samsung laser printer?
My 4 yr old Samsung CLX 3175 laser printer leaves ink smudges. Sometiomes the effect is as if wet ink sheets were stacked up and rubbed off, often there are also yellow curved smudges, usually in 3 separate spots fairly evenly spaced in a row. I have wiped everything clean that I can reach internally. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
When did this happen?
댓글 달기
답변 2개
가장 유용한 답변
This problem occurred in my Samsung CLP-315 after I replaced the black toner cartridge. It disappeared after shaking the cartridge horizontally and gently tapping it in order to loosen and spread the toner more evenly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Maybe it is too much ink. If it is refillable ink, just use the perfect amount of ink into the cartridge.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Steener 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 3,376
