Why is my display has a vertical line
why is the display has vertical line
좋은 질문 입니까?
Bernard Jones, if it is a single vertical line, it most likely is a bad binding (TAB) error on the LCD. Of course you do want to make sure that the cables are properly seated, but my first choice is a bad LCD panel.
해당 답변은 도움이 되었습니까?
LCD panel. To crush any hopes and dreams of it being the cable, before someone chimes in that it uses the cable, be reminded that displayport is a works-or-doesn't-work protocol. It isn't like LVDS which is based on difference between lines. It's the LCD.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,416
