주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
Battery not recognized after liquid damage
Hi, took this logic board out of a Macbook air 11'' mid 2013 model, the MacBook works fine, except the battery won't charge, the macbook doesn't even want to see the battery, battery sign doesn't even come on , on the desktop.
Need some help finding out the faulty component on the logic board.
Ive got the schematics and board view
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I have this problem with my macbook air. I took it to an Apple affiliated store and they want $599 to fix it. If you can get help with this, please help! Thanks!
댓글 달기
답변 1개
I think, that the problem might be in the battery, you should check the battery /motherboard connector. That usually might be little bit out of it’s position. The motherboard seems to be clean. It does not have any problems, as I can see.
  • You should check the connections
  • if you have another macbook / mac, you should try the battery with that macbook / mac
  • The liquid damage could even damage the battery ( like it might be dead, if a little bit of water went into connections ), so you should look a bit into that also
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Waseem 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 188
