주요 콘텐츠로 건너뛰기
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 질문 전체 보기
replace the left rear door lock actuator
I need to replace the left rear door lock actuator and it makes a honking noise and does not lock the door.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
petersea8 , Jim, The link below shows steps to access the lock to change, a video link and link to replacement part to give an idea of what to look for. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://jeepslimited.com/index.php/write-...
https://www.youtube.com/watch?v=bmGBVSgu...
https://www.1aauto.com/jeep-grand-cherok...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Jim, pretty much teh same idea as on here.
REMOVAL
(1) Remove door trim panel,
(2) Disconnect latch and lock rods from inside handle actuator.
(3) Remove screws attaching inside handle actuator
to trim panel
(4) Separate inside handle actuator from trim
panel.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I looked up how to "Replace left rear door lock actuator", I tagged on the link and got this video on how to remove the door panel, problem is I had already gotten that far and then wound up putting it back on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 3,449
