주요 콘텐츠로 건너뛰기
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
76 질문 전체 보기
How can I fix my charging port
Can anyone tell me if its even possible to fix or is there another way to charge it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 10
댓글 1개
I also have this problem where the weak little charging port no longer works.
댓글 달기
답변 6개
가장 유용한 답변
bubbiesmommie try this. Hold Windows key and tap x to get into device manager.
Click on batteries
Right click and delete the battery
Reboot, the system should "find" and "re-install" the battery.
Then plug it is and see if it charges.
If it does not, then you definitely want to try a new cable and a different charger. If even those things don't work, then you'll have to disassemble your T100 and take a look at the actual charging port and ensure that it is properly soldered on the board etc.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
i trhink my charging port is broken and the socket are not in place
do you have an idea on the solution
댓글 달기
I'm trying to figure this out, too. The route I'm thinking of taking involves the following three links. One shows how to open up the tablet, one shows how to replace the micro-usb port, and the third is a link to the correct part on eBay.
https://www.youtube.com/watch?v=YxxpLYf1...
https://www.youtube.com/watch?v=4urOi3zu...
http://www.ebay.com/itm/Micro-USB-Chargi...
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
how was it? did it do the job? my kids messed up my charging port too! need to fix it.
댓글 달기
Use a magnifying glass and good light to look into the USB/charger port. Take a tooth pick and gently apply a small force to the center tab in the port. See if it freely moves. If it is not rigid it is busted. If it is busted be very careful about trying to follow the youtube instructions. Not all T100s are the same. In my case the screen and bezel are glued and the bezel is screwed to the base. And yes you guessed it, the screw heads face the screen. In this case if you try to pry the screen and bezel out you will crack the screen. The only way to get it apart is to heat the screen and separate it from the bezel first so you can get to the screws. And I am pretty sure that will fail. Some of these T100s were not meant to be taken apart. Thank You Asus for using a flimsy micro USB port to charge the tablet and also making the tablet that can not be serviced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi! Heating the screen can be dangerous.
댓글 달기
Had a similar situation myself. I opted to replace the port, & exact replicas are 5 for a couple $ on ebay. Since I don’t have a micro-soldering station (& I use the port only for charging), I broke off the pins used for data on the backside, then very carefully resoldered the port and 2 power pins back in their original position. Then just to add a bit of strength to it I put the board back in its casing, & added some hot glue over it. That was probably a bit overkill, but it was only my 2nd attempt to work on a Transformer MB. Note* Be extremely careful when attempting to remove the board from the casing. The flat orange cable (Main LCD connector?) has some very finicky little pins which will make all efforts to repair null & void if bent. All connections inside should removed with as little force as possible, & preferably done under some magnification.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, be careful about hot glue, electricity, etc. It may cause fires or electric shocks.
댓글 달기
my port stops charging every 1 year and after 2 years it starts to work
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Has anyone tried solder a apple lighting to port to device that have micro USB
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
bubbiesmommie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 20,178
