주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
iPhone 6 antenna problem
I have network problem with my iphone 6.
The problem is sometime i lost signal. I have analize around and found that i have problem with my antenna. When i lost signal all i need to do is squeeze my iphone and the signal will back to normal.
My question is ;
How is bottom antenna work? I heard that iphone 6 use bottom part as the antenna itself but where is the connector. I only found one connector bellow battery connector and then no more so how i can fix network problem on my iphone?
Please dont ask me to reset since i already fix and now that this problem is hardware problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
가장 유용한 답변
This should not be related to the antenna.
iPhone 6 has at least 2 antennas for cell signals and they work at the same time. One is the top band and the other is the dock flex with the bottom band. The lower RF coax cable from next to the battery connector goes into the dock flex and the flex is screwed down onto the band.
If the phone just loses connection when the signal is not bad, usually it's more likely that the cell tower setup/SIM card/baseband firmware is the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Would this be picked up by apple on a diagnostics check ?
댓글 달기
Change antenna switch ic
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jeandseen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 9,146
