주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2007년에 출시된 22인치 16:10 LCD 모니터입니다. 이 모니터는 일부 Mac OS X 버전에서 보정 없이는 눈에 띄는 색 정확도 문제가 있을 수 있습니다.
My monitor won't lite up
AL2216W monitor
My monitor won't lite up. The power button is lite (green) but no display.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Fixedit! changed the 5 caps, resurrect my 10 years old AL2216W!
My caps are fine and the two boards are fine. It is the backlite that are gone. can someone tell mewhere to get the backlite replacement?
Replaced the caps on two monitors and they work again. No power led when turned on.
댓글 달기
답변 2개
선택된 해법
Check the capacitors for swelling and/or corrosion: Acer AL2216W 커패시터 교체
이 답변이 도움이 되었나요?
점수 3
댓글 8개:
I have bad capacitors in my AL2216W, too. Is this guide still available somewhere?
I do not know why access is now forbidden. I'll link this question to someone at the iFixit staff and see if they can fix it! @kaykay
Hi @mayer. That particular guide has been set to private by the author—looks like he might be working on improving it.
Is it Nicks?
Yup. Looks like he's been working on some edits.
댓글 3개 더보기
댓글 달기
Check for an image using a flashlight. If it's stable, then it's likely a bad backlight tube or capacitors. However, it’s generally a capacitor fault that can be salvaged with a complete recap of the power supply board.
If the capacitors look okay or a recap didn’t work, the problem usually lies with the power supply inverter or the CCFL tube in the panel. Sometimes this is fixed with a power supply, but it rarely fixes the problem when a recap doesn’t work. Mine lasted ~1 year with a recap and ended up with a failed backlight the second time (check for a black end on the tube). It’s generally difficult to replace this and you usually ruin the panel in the process if you never done it before.
The problem in your case is it's likely like mine where a new power supply won’t fix the problem because of a bad panel as the failure of the backlight is more unique - when the tube fails, you usually lose it within seconds while a capacitor failure is more gradual and doesn’t happen without warning. Since the panel is old, expensive and out of production, you’re better off recycling this and replacing it if the caps pass. Beyond attempting a capacitor replacement, it isn’t worth repairing the monitor.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
oscarpro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 4,073
