주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP의 G72 노트북은 17.3형 대각선 고화질 디스플레이와 세련된 디자인, 준수한 사양을 갖추고 있습니다. 또한 합리적인 가격의 데스크톱 대체품으로도 손색이 없습니다.
My daughter's computer won't start!
This is my daughters computer and awhile back the battery stopped charging. She told me that when she would start it a message would come up asking her to press enter to continue. She got in the habit of hitting enter so one time she hit enter before she was asked and the screen went black but the computer stayed on. After awhile she unplugged the power supply to stop the hard drive from running. Since then the computer has not turned on at all. Can I save her computer or has it seen it's last?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개:
The message that came up that she bypassed by hitting enter, was likely a message inform you that the battery needed to be replaced. Currently, you stated that the computer does not turn on at all. Does this mean no lights come on when it is plugged in or is the screen still black.
의
What happens when you remove the battery(if you can) and just use AC power?
If you can't boot, her unplugging and the battery being bad might have corrupted the hard drive. You might have to reformat it to get it to boot again.
This seems like nothing serious to be honest.
의
댓글 달기
답변 1개
This could be due to a number of problems. First, the hard-drive might have shut down incorrectly. If the problem is indeed caused by the battery, try using a different ac adapter. The one that the laptop had been using might have a bad capacitor. The laptop might also have to be plugged in when its being used. Another problem could be with the RAM on her computer. This is unlikely, but does produce symptoms like this. To fix that, you would have to unscrew the screws on the bottom of the PC. Once you remove the panel, you should see the RAM sticks. Try switching these around. Here is a guide: HP G72 메모리 모듈 교체
There are many problems that could be occurring. These are just a few that could cause a problem like this.
Good Luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 553
