주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tengda S5+는 멀티 터치 바 타입의 스마트폰으로, Tengda S 시리즈의 최신 모델입니다.
My battery won't charge?
I've had my phone for about a year now, and for some reason the battery won't charge when I plug it into the charger?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Charging not store
댓글 달기
답변 1개
가장 유용한 답변
Hello Jholmesford,
  • Accessory may not supporting to your device
As you got high capacity (3.2Ah) battery it required original charging accessory to use otherwise it will take long time to get fully charge. When you plug the original charger phone will automatically change the charging mode to rapid charging and phone will be charge around 80% withing 1 hr and 30 Mins. if you don't have original charger you may required to use 5V 2A Charger.
  • USB port
Check whether any sign of damage or corroded in micro USB port. if it is you can clean the port
  • Power source
Check in the setting whether you phone identify the power source, Connect phone to charger Path: Setting - About phone - Status- Battery (Charging should be AC) anyhow it shows as USB there is something wrong with your USB port or Power IC
Hope this answer help you to troubleshoot the fault.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jholmesford 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 556
