How to change fuel filter 2007 jeep wrangler
Where is the fuel filter on my 2007 jeep wrangler JK and how to replace it?
좋은 질문 입니까?
좋은 질문 입니까?
fxdwg96pete, on your model there are two fuel filters being used. One at the bottom of the fuel pump module and the other inside the module. This Jeep does not use the older type that were mounted to the frame etc. It is also not necessary to replace the filters as part of a routine maintenance. You only change these in case of an engine diagnostics. i.e. OBD code. A separate frame mounted fuel filter is not used.
해당 답변은 도움이 되었습니까?
24 시간 전: 6
7일 전: 30
30일 전: 137
전체 시간: 24,937
댓글 2개
We’re is in line fuel on a 07 Rubicon
Darrell Mullins 의
How to determine her a bad Throttle body
Darrell Mullins 의
