Ipad is not charging after using a half broken usb cable
Hi , My Ipad mini is not charging anymore, no matter what usb cable I use ,I had a half broken usb cable, I think its unstable voltage damaged somthing, now when I plug in my new cable it detects it, because the "no battery, plug in your charger" shows up without touching any button,but it wont charge,
https://support.apple.com/library/conten...
(this is what happens when I plug in my charger)
and sometimes the apple logo shows up and my ipad actually turns on(when I plug in the usb cable) with 2% battery, but even then it won't charge, what is causing this problem?How can I fix it?
좋은 질문 입니까?
댓글 4개
"had a half broken usb cable" broken where and how. It got nothing to do with unstable voltage and everything to do with shortening out.
oldturkey03 의
some wire inside the cable was broken and I had to dance around my cable to find the spot that charges,
the whole charging process was unstable,even in that spot,because if a butterfly flyied the other side of the world,I had to find that spot again
Azim Meygooni 의
and you now use a new cable and your iPad does no longer charge?
oldturkey03 의
yes,and those weird things happenes
Azim Meygooni 의
