주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Dropped my phone now I have colored lines on the entire screen
I dropped my iPhone 5c on a hard surface, and when I picked it up I saw pink/red lines across the screen. After I hit the lock button, the screen is normal but after about 10-30 seconds pink and red vertical lines appear across the screen and it stops functioning until I press the lock button again. Is there a way to fix this problem or does the LCD screen need to be replaced?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 32
댓글 25개
Just happened to mine and it won't work but I can never get service and I got it after I dropped it
I have a 5s I never dropped it or boyging I went to check the time n there was a green line so I cluxked the power button and it never turned back on , can I take it somewhere yo be fixed or is it done for?
Is this optional? I can live with the lines in my screen. I just want to know if I dont fix it, nothing bad would happen.
[After I wrote this comment I noticed the lines faded away. You'll be fine. Sometimes they fade away. Just wait.]
My phone fell and it started like blinking with no-colored lines on the screen. I hit it again to see if it stopped, and it did, but then I turned it off for it to "rest" for about an hour. When I turned it on, the blinking appeared again. It still works but sometimes it stops and sticks in the screen. What can I do, rather than changing the LCD display. Plzzzzzz helpp!
Don't worry I have a iphone 5 SE and that happened to me I let it sit for 5 minutes went back to normal
댓글 20개 더보기
댓글 달기
답변 10개
선택된 답변
Yes, sounds like you're going to have to replace the lcd panel. The good news is it's very easy to do on a 5C
iPhone 5c Screen 이미지
상품
iPhone 5c Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 9
댓글 8개:
Will a soft/hard reset solve the problem too?
how on 5c just happened to me
How exactly do you replace the lcd panel?
is this easy to do on an iphone 5s?
Is this optional? I can live with lines on my phone. I just want to know if my phone will glitch out like crazy or anything if i dont fix it.
댓글 3개 더보기
댓글 달기
The display cable may have come loose, so before you replace the display, follow this guide and make sure that the display data/digitizer cable is properly seated and is not loose. Disconnect the device from power and shut it down before opening, and disconnect the battery before attempting to touch any other connections. Reassemble the device and turn it on. If this doesn't change anything, you can order a replacement screen here.
상품
iPhone 5c Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
To tell you the truth... My mom gave me her hand-me-down government phone(getting a phone mabey for Christmas), and she dropped it at the store and claimed her battery was low on her phone. So when I looked at the screen, I saw green, blue, purple, red, and yellow lines going vertical (up and down) on the screen. Fortunately, the phone still works, but it's really annoying that I can't play my minecraft because of this situation.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
You will need to replace the LCD extremely easy to do on a 5c luckily you can get a new on eBay for $20
is it just the panel Austin or can i get a new screen
or do i just get inside
How do I replace the LCD.
댓글 달기
You need to pop your finger in bottom...it might not fix it, but it will distract you for a short time.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I dropped my phone and the screen shattered. It still works, but there are color streaks. Is that just a side effect of the cracked screen or is something else damaged too?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It's just a cable came out of the socket all you have to do is go into the screen and make sure all the cables are hooked in properly
댓글 달기
i cant even see my screen nore answer phone calls its so annoying I have had enough
Update (03/06/2018)
it works but it doesn't let me see any thing on my phone at all and not only I cant see any of my texts or phone caller id no more as the phone has given in on me and now cant use it again
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
this happened to me too. I am getting a replacement phone and sending the broken phone back so they can fix it. try that
댓글 달기
Hi I ordered a screen for my grand prime but instead a duos screen came, Can I work for my phone?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Idk, my phone is having gray lines horizontally across the screen. It is the iPhone 5c. I am anxious to go to T-Mobile to get it fixed. Does anyone know what is wrong with it? It happened after I dropped it. It was fine for about five minutes then I was sitting down and the lines were there.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is happening to my phone as well after i dropped it. Ugh I can't even watch Netflix.
댓글 달기
My iPhone 5c keeps on restarting and also leaved some lines on the screeen any time it's goes off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I really want to know the course. Thanks
댓글 달기
You will need to replace the screen assembly. I would first check if the connection has come loose!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Craig Spring 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 78
30일 전: 333
전체 시간: 477,220
