주요 콘텐츠로 건너뛰기
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 질문 전체 보기
Does a heat gun actually melt solder?
I watched your tutorial "Yellow Light of Death Repair" to fix my console but was confused about re-soldering it. I was expecting to see how to re-solder the chips but all I saw was using a heat gun.
In my own experience I have never know a heat gun to be able to melt solder. So what is the point of making it hot? Its not actually heating the solder to the melting point is it?
Thanks, Joe
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
The heat gun iFixit sells will definitely melt solder, plastic, light your wooden work bench on fire, burn the crap out you and light your cigarettes and cigars, It has two heat setting and is a great buy: Heat Gun
Heat Gun 이미지
상품
Heat Gun
$24.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
i have sure burned the crap out of things with my hot air station. mine is temperature controlled to 500+ degrees celsius. considering that solder melting points are far less than this then yes I'd say the heat gun will melt your solder.ps i don't understand fahrenheit but that gun gets to 1000f…sounds dang hot!!
댓글 달기
zep101, this is a twofold question. First let me try to answer the "heatgun" issue. For that I would like to direct your attention to the "semi scientific" experiment right here. Yes, it does melt solder.
2nd part of your question is the why you are using the heatgun. It is a bit more intricate to explain. The key to this is the design of the GPU which is a flip chip design. The proper definition of that can be found at Wikipedia "is a method for interconnecting semiconductor devices, such as IC chips and microelectromechanical systems (MEMS), to external circuitry with solder bumps that have been deposited onto the chip pads." So what happens is that the chip heats up (due to poor design of the ventilation and heatsinks of the console. Does not matter if it is a PS3, a XBox or some of the Mac laptop's) and the bumps that connect the chip to the substrate lose contact and your chip (in this case GPU) fails. The heating of the chip for the reflow actually reshapes (most of the time) the bumps to the point of making contact again. That is the reason why some of the reflows just do not work. The connection between the IC and the substrate has absolutely failed. Not the most scientific explanation but I hope it makes sense to you.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
zep101 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 7,715
