주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Screen goes mad after replace battery
Hello,
Yesterday we received a new battery for our iPhone 4s, it was changed successfully and it does work very well, but when closing the cover, the screen goes mad showing lines, inverted colors, etc.
It seems to happen because the battery is pushing the screen from the slot.
That's not happening with its own battery... any idea?
Cheers,
Luis.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Compare the new and old battery to make sure they are the same size.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I did it several times, the only thing I did was remove some bubble and crease the black cover of the battery had. It seems the screen stopped doing it, but if I slightly press the back cover it sometimes can go mad again.
One thing I realised is that the mobile does not have white plastic that should be under the battery, but it did not have it with the old one..
Is that plastic necessary?
댓글 달기
Cover the battery by sellotape
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
iquark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 67
