What shall I do for this problem?
i just dropped the phone .. and it just turned off ??? it only give a response with the charger ??? but it doesn't charge ?? check the video :/
좋은 질문 입니까?
좋은 질문 입니까?
Hello Friend.
Opens the iPhone, and disconnects the battery, possibly with the fall, he puffed, and this failing.
Disconnect the battery, and try to turn on iPhone, connected to the charger.
I think this will make him turn on, if so, have to change the battery.
here you have to guide
to test, you do not need to take off the battery, just disconnect it.
Good job!
해당 답변은 도움이 되었습니까?
Here is how you can start your iPhone without power button:
Attach your iPhone to USB cable.
Using the cord, plug your iPhone into computer or any other charging device
It will take few minutes for your iPhone to get switched on. Once, it happens, you will see screen lights with “slide bar” option
Swipe this option to unlock your iPhone.
above steps worked you will have to replace power button as it damaged due to drop,
해당 답변은 도움이 되었습니까?
Have u watched the video ??? It doesn't do any thing upon connecting the charger ???
you should start to troubleshoot from your power switch. here is the teardown guide
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 83
