주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
질문 마감됨
dc in board not charging replaced
i recently purchased a macbook pro 13 secondhand off of craigslist and has worked fine since
i had a problem with my charger and it threw a spark and burnt the DC in board so i opened it up and correctly removed it and replaced it with another brand new board i had purchased.
I followed the guide on ifixit and have succesffully managed to put it together ect.
it however does not show any sign of charging Nor does the unit the turn on
*battery died due to using it off charge*
i have no lights indacting charging on the magsafe adapter..
all my cables have been checked twice to ensure there connected
is there a reason why i might not be having any luck?
Also my bottom case is off.
Does it need to put on for the charger to activate ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
First check the output of the magsafe adapter before going to board level repairs. See the pin out on the right side of the page here: https://en.wikipedia.org/wiki/MagSafe
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
1) Find a boardview and a schematic online for 820-2530 logic board. This will allow you to locate components on the motherboard so you can check them. I can't help you with this because it is illegal to distribute Apple schematics and boardviews, but for twenty bucks a bunch of vagabonds in foreign countries will happily oblige(I am not one of them).
2) Measure for voltage on pin 5 of U6901. Black probe of multimeter on a screwhole, red probe on pin 5 of U6901. 3.42v, or something else?
3) Measure for voltage on pin 1 of VR5020. It should be 3.42v.
4) If voltage on in 1 of VR5020 is 3.42v, and voltage on pin 5 of U6901 is not 3.42v, then run jumper wire from pin 1 of VR5020 to pin 5 of U6901.
This will help you gain some understanding.
https://www.youtube.com/watch?v=FLH2Ns7Z...
https://www.youtube.com/watch?v=sI7rvFLU...
Ultimately if this requires anything more than running a wire between those points it is kinda junk for the purposes of reviving a six and a half year old machine. You can find boards on eBay for $177 and free shipping for this. If you really want to go down learning board repair to fix a core 2 duo I will happily follow up here, but I don't believe it is worth the time or effort for a machine that came out before I could legally buy beer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 167
