주요 콘텐츠로 건너뛰기
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 질문 전체 보기
Why is my controller over heating, and not vibrating?
I found that after a month or so after buying the Call of Duty Xbox One. That the controller that it came with began to over heat and not vibrate. I also have found that the plug and play rechargeable battery that I use loses power very fast as well in this controller, but does not in the controller it came with. I have tried doing a firm ware update with it, and followed all of Microsoft's troubleshooting tips but nothing has helped. It says to send it back to them but I would like to fix the problem on my own.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
The wire from the vibrating motor probably came loose and is now touching other things in the controller causing the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If your Xbox One Wireless Controller no longer vibrates when it’s supposed to, see the Xbox One Wireless Controller Won’t Vibrate problem page for possible problems and solutions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
siebener 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,005
