주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 PlayStation Vita인 PCH-2000 시리즈는 일반적으로 PS Vita Slim 또는 PS Vita 2000으로 불립니다. 2013년 가을 일본에서 발표되었고, 2014년 5월 북미에서 출시되었습니다. 이 기기는 휴대용 엔터테인먼트 기기로 분류됩니다. Wi-Fi, PlayStation Now, PlayStation Network/Plus, Bluetooth를 지원합니다. 모델 번호: PCH-2001.
Left Analog stick stuck in 'up' direction...?
hey,
im from Australia but i am currently living in Japan.
my ps vita's left analog stick is not working properly. it is stuck in the 'up' direction even if im not touching the device. i have had this vita for just one year and look after it well.
due to this issue i am not long able to use my vita anymore. and it is very frustrating because i really enjoy my vita. what am i able to do to fix this problem? i have tried rebooting the system to the default settings but that did not fix the problem. please let me know asap.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
Me to but mine goes down ward . Where can I find a replacement joystick?
댓글 달기
답변 2개
가장 유용한 답변
Hi, i know this is an old question but it seems to be a very persistent problem for the PS Vita community, i had to deal with this for about a year and a half and nothing but replacing the joystick worked for me.
I Love my Vita, but the joystick problems on the slim model are very frustrating, this are the things that i tried for the past year and a half:
- "Recalibrate" the joysticks by moving both clockwise during boot (Useless).
- Blow on the side of the affected joystick (There's a posibility to make the problem worse, moisture from your breath can get on the contacts and cause corrotion).
- Take the vita apart and use a compressed air can or WD40 electronic contact cleaner on the side of the joystick (This seems to work for some people, but for me the problem came back after a few days).
- Replace the joystick (This is the absolute fix for the problem, though it requieres some knowledge or practice on taking apart electronics without damaging them, the slim model is very thightly packed and easy to break).
The replacements can be found on eBay, just look for "ps vita slim joystick replacements", i got mine for just 1 USD from a chinese supplier, they aren't original but that's really not an issue other than aesthetics since they do look very different from the originals.
I hope this can help other people looking for a solution.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Having same problem. You need to replace the joystick.. I'm currently doing is now...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi
where did you found joystick?
I am in Italy and I cannot find it...
댓글 달기
답변을 추가하세요
scastletwyford 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 36
전체 시간: 9,773
