Timing belt on my 2002 Volkswagen Jetta
So I was driving down a parking ramp and my timing belt broke I immediately coasted into a parking stall and turned my car off once it died are my valves still bent?
좋은 질문입니까?
좋은 질문입니까?
Ryan, due to the limited clearance between valves and pistons you will not know if they are bend unless you check it by removing the cylinder head or performing a leak down test.
이 답변이 도움이 되었나요?
What you need to know is what motor is in this car before you make any kind of decision on damage. If the engine is a 1.8 turbo then no damage as it is considered a non interference engine under no circumstance will the valves hit the cylinder head. Even if the timing belt break the 2.0 is a different story as it is an interference engine and the valves will top of the cylinder head if the belt breaks.
이 답변이 도움이 되었나요?
by the way a leak down test is the easiest way to know without disassembling the engine.
You are incorrect the 1.8 t is a interference motor
So I guess having a bolt lodged in my timing belt and crankshaft sprocket during a take off after stopping,makes me up $@$* creek without even a boat.
For future individuals who stumble onto this thread. The 1.8t is absolutely an interference engine. Very expensive and you will have some valves bent 100% of the time usually 80-100% of the valves being damaged. Head will likely need to be replaced not rebuilt if a timing belt breaks in the 1.8t. The 2.0 petrol is also interference but people sometimes get lucky and have no damage when a timing belt breaks. Most of the time they are also damaged.
이 답변이 도움이 되었나요?
A 2.0 engine is a non interference engine it's on all the list all car and have damage but 2.0 in non and 1.8 is definetly an interference engine.
Only if your 2.0 is an 8 cylinder and not a 4 cynlinder.....
Yeah it’s absolutely an interference engine. Not sure why people argue this point when every repair manual states the fact. Only places that I’ve seen it reported as non are in groups and forums. Regurgitated bad information. I’ve seen them bent more times than not. That being said I’ve seen a couple of times people got lucky on the 2.0 8v.
Sensor bad but first follow the wires back to ecm. Run your nails across the wire to check for breaks in wire. The problem is you can check with a meter and it will say you have continuity but if just one strand in the wire will say this . so if the rest are torn you will still get a code. It's tedious but this will tell you if you got a bad wire. Those geniuses stretch these wires and tend to tear after time. They stretch them so the readings are closer instead of having a wire to long for readings. I went through all of mine and I found 12 wires barely making connection. Good luck be patient ,you Will probably be cussing your brains out though.
이 답변이 도움이 되었나요?
@reyduran328 ok I will attempt to check that tonight after work I’ve been told to check the wiring on ecm and the wires to crank shaft sensor I’m determined to resolve this issue and whenever I do I will post for future reference for everyone I was going to buy new wires for the tune up I did and also buy a crank shaft censor since it was reading bad but will check the ecm wires first and fully test it thank you for your response because my mind is about shot fooling with this car Been messing with it for about 14 hours now testing everything I can to figure out the issue
Cam shaft censor was the issue. Only one side had power to it due to the magnet breaking behind the pully. Was able to figure out pretty quick with voltage reader
이 답변이 도움이 되었나요?
Thanks a lot for the input helped a lot on trouble shooting
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 27,574
