주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
Front facing camera shutter stuck?
Hi,
I'm having some real issues with my phone at the moment. I've just done a screen replacement and just as i thought all was finally fixed, i went onto the camera. It first appeared to work fine (this being the back facing camera) however when switching to the front facing camera the shutter doesn't open at all. Here's a picture of it :
It's annoying as always when you fix it, another thing happens. I'm not too sure what's happened with the camera as the phone wasn't in working condition when i bought it, so it may have been not working before i got it. It just seems to be the front camera that's gone wrong somewhere along the line.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
UPDATE: Just replaced the front camera and that hasn't worked!! I now have no idea what to do..
댓글 달기
답변 2개
선택된 해법
First make sure nothing is obstructing the camera on the new screen that you installed: remove the camera and look against the light.
If that's not the issue, use a magnifying glass to examine the board mainly next to the front camera connector, but also next to all the other connectors in that area. Let us know if you find something missing/damaged/corroded.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Make sure the front camera cable is properly seated on the mother board. It also possible that the cable was damaged during the repair and may need to be replaced.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks for your reply. I've checked and it seems that the camera connections are connected to the phone fine. I tried taking it off and on again ,but no luck. I've just ordered a new front facing camera now so hopefully it'll work! Thank you
댓글 달기
답변을 추가하세요
Stewart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 206
