주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Why is my iPhone 5c freezing and wifi disconnecting itself?
I bought a Iphone 5c from ebay a while back. It acted weird since i first used it. The phone would randomly freeze when trying to open apps.
The phone also have problems with the wifi. the wifi will just disapear, and i have to hard reset the phone to get it back.
Any sugestion on what's wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
The phone wifi bar is showing signal, but the internet will not work. Hope someone know what to do.
댓글 달기
답변 2개
선택된 답변
It's possible that it may be water damaged.
Did they have a return policy? Did they describe it as working fine? Or did they describe it had faults? If they didn't mention any faults you have every right to return it and get your money back. :-)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hello.
The item was described as 100% working
They had a 30 day open return, i will try to get my money back. Thanks for the answer!
댓글 달기
Hey Vegard, did you try to restore the device? It happened to my friend as well. I told him to restore and everything was back to normal. I think this could be a corrupted iOS and restoring could be the solution. However, if restoring the device doesn't help, then it is a hardware problem. Also comment me if you ever dropped your device or if there was some sort of water damage before.
-Let me know how it goes.
-Please accept this as the answer if it answers the question.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hello. I tried restoring the device but had no luck getting it working 100% again.
댓글 달기
귀하의 답변을 추가하세요
Vegard Jakobsen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 878
